Just moved the PC into the bedroom and while waiting to put everything back together, I decided to do what any normal guy would do... upgrade some stuff. :biglaugh:
One of the main things I will be adding is a USB DAC that will connect to my Marantz 4002. Currently using an XFi Xtreme Music sound card.
So what have you tried in the sub-$300 range? In reality, I will most likely keep it around $200 or so but wanted to open it a little to get more ideas.
So far, I am considering Fubar II and KingRex UD-01.
