I had unhooked a bunch of my gear and was moving it, and somewhere I misplaced the power brick for my external SATA enclosure. Kind of a pisser because I need my files back up :) Is there such a thing as a universal power brick? I know the voltage, etc; on the old one. It's some OEM job though, so I can't just get a replacement from the manufacturer :crying:
Universal power brick?
8.3 amps??? Wow is that case a converted space heater? :D I just checked a couple here and they need 5vdc and 12vdc but even if you add them up they are only 25watts ([email protected] + [email protected] = 25watts) on the output. The input side coming out of the wall is rated at 0.6 amp which is around 65watts.
So huh where did that 8.3 amps come from? What voltage? Output or input side?
