Learning to build crossovers
  • Learning to build crossovers
    Hey guys, I have had the parts in my garage forever to do my own cheapo line array using the good old PE NSBs :) Not going to challenge the LS6s or anything, but it should be fun. One thing I need though is a way to handle the crossovers, either by building some or doing it with electronics. Anyone have any good resources for building the crossovers? I know where I want to cross over the NSBs with the woofers and the tweeters I have :)
    I'd be interested in this answer too. :)
      Parts Express sells BassBox 6 and X-Over3 as a bundle as BassBox6 Pro. That is what I use to try virtual speaker designs. Once you have Thiel-Small parameters for the drivers in BassBox6 and design the box, the output goes to X-Over3 to design the XO. I found it on sale at one point at PE.
      There are other programs out there if you look around. I have a friend that used BB5 and got me started with it. BB6 is a nice improvement.
      EDIT: It also supports line array designs. :)
