Looking for a nice tube integrated to go with my X-ls encores for an office system. Near field listening only. budget is under $1000, and a remote would be nice but not required. Thanks
Tube integrated
Originally posted by uw69Looking for a nice tube integrated to go with my X-ls encores for an office system. Near field listening only. budget is under $1000, and a remote would be nice but not required. Thanks
Plenty of others options in that price range as well.
If you want to go new I think the Xindak stuff that mls plans to distribute looks interesting. LINK
I'd also suggest looking at used modern tube integrateds, you get a lot for the money, they've usually been babied, and you'll often get a set or two of different tubes for tube rolling.
For the x-ls's I think 12 wpc would be OK for nearfield, but I would probably want more power to get better bass control. I'm running my x-ls's with an under $500 Yaqin MC-10L that gives 50 wpc (probably more like 40 wpc clean) and that is a very nice combination.
If were buying today, now that I'm used to tubes I'd be looking at used ones on Audiogon.
Jim C
Originally posted by uw69Are you using the stock tubes or have you replaced them?
As nice as the Yaqin is for the price, I also have an Onix/Melody SP3/8 driving my Mini's and I think it is a better amp if you can find it used. The only real drawbacks are there are only 2 inputs, and the more popular tube complement means higher prices, but much greater selection.
I also saw the Xindak line at RMAF, and they looked really nice, but I didn't get a chance to really listen to them.
Before you decide I'd also do some research on sites with a lot of varied tube opinions like Audiocircle and Audio Asylum. Like I said if I bought now, I'd be looking through the various classifieds and on Audiogon for someone upgrading.
Jim C
