Current options to replace MFW-15 amp?
  • Current options to replace MFW-15 amp?
    Hey all,
    It's been a while since I've posted, but I think my AV123 MFW amp is about to die. While on, with no power to my receiver, the amp will make that noise like someone is fiddling with a turntable needle. It's quiet, but there.
    Unless you guys think it's something other than the amp, I need to find out what my replacement options are. I'm in the middle of wedding planning, so I can't go all out and spend money on a new sub setup. Most of the old forum posts are 2+ years old.
    Anyone out there able to point me in the right direction?
    This is the only drop in replacement I know of. Amp, new driver, plates to cover openings. $795 + shipping.
      I don't think putting $795 into that sub is worth it unless you're attached to it for some reason. Technology keeps marching on and you could buy something new that would be a vast improvement for that kind of money. What I would do is remove the factory amp, measure the cutout dimensions and maybe we can source an amp that would be a good match for the MFW driver.
        Let me know what you find.
