Lexicon MC4
  • Lexicon MC4
    Anyone have any info on an oldie but goodie the Lexicon MC4? Specifically will it adjust flatten the sub curve. Will only use in 5 channel and 2 channel for music, music 65%. Thinking the quality of this and say a rotel 1095 5 channel may be better than the quality of new avr's wich seem to be a bit tinny latley. will be matching to the arx 5 or 7s when available (please be by christmas john) then following up with the 18 sub and an amp. (maybe 2 18's :) )
    Looking through this review:
    http://www.hometheaterhifi.com/volum...sp-7-2005.html
    It appears there is no correction of any kind. But it is a pretty good digital surround controller, albeit a bit pricey, but name brand.
    This might be worth looking at:
    http://emotiva.com/products/pres-and...ing-soon-xmc-1
    Rumors have it debuting soon.
    But in all honesty, something like this is what I would recommend:
    http://www.accessories4less.com/make...-150wpc/1.html
    A4Less is a great souce for Factory Refurbs & you can get a 5 year extended warranty for $50, which is better than a new warranty. And it comes with Audyssey Platinum (think Audyssey XT 32, Sub EQ). This is a total package that gives you everything.
