Some hate em, some love em...guess ill find out. Always wanted to try a pair of full range xoverless speakers, so I scooped a pair up off audiogon. They are upgraded with mundorf silver in oil caps and the latest nanotech drivers. Same drivers they use in the definitions...
Should be interesting...should have by this weekend. Some specs:
Zu nanotech drivers are now standard equipment (Zu103ND/G1-16) these are the same units developed for our Dominance and as used on Definition Mk.IV and Mk.III. They feature our high-output motor assembly, 16 ohm magnetically neutral-hung voice coils and paper-cored nanotech cones. No other changes are done. Original Omen Def loudspeakers can be field upgraded. Markings for Omen Def Mk.I-B are: REVISION-B nameplate and the engraved model identification on the drivers’ center cone.
High efficiency, high output, moderate impedance, direct radiating, floor-standing loudspeaker. Omen Def Mk.I-B features Zu’s full-range driver (Zu103ND/G1-16), in the Zu Definition architecture, ZuGriewe driver/box/room acoustic loading technology, no crossover or filters on full-range drivers, complimented by a dynamic tweeter featuring phenolic-composite dome and machined 6061-T651 billet lens, providing the acoustic sparkle and resolution from 10kHz and up.
Mk.I-B June 2012, shipping August 2012 (Mk.I-A November 2010)
47x12x12[119.4x30.5x30.5cm]
12 x 12†[30.5 x 30.5 cm]
78 pounds [36kg]
FlexPak, one loudspeaker per shipping box, 84 pounds [38kg]
2x Zu103ND/G1-16, 10-1/3†full-range nanotech driver in Zu Definition array covering 30–12,000 Hz Zu/U-APT-L2 tweeter assembly
better than 1% driver pair matching, 0.1% on all other electrical components
accepting: 1/4†spade [6.3mm fork], 5/16†spade [8mm fork], bare wire ≤ #4 AWG, banana plugs
100dB SPL @ 1W/1m
8 ohm, nominal full bandwidth (5 ohm minimum at 270 Hz)
78 pounds [36kg]
100dB SPL @ 1W/1m
