Hey guys, I picked up 5 X-Amps a few weeks ago and they've been performing flawlessly and sounding great ever since I got them. They run a bit hot so I've spread them out so they're not stacked at all on each other, just in a nice long row with those nice blue LED's staring out :applause: Well last night I came home and I looked and saw one of the LED's was out. I was curious and so I reached behind it to make sure it was on and it was. I unplugged it from all connections, pulled out the fuse, saw it was blown, and replaced it. I plugged it all back in, flipped the power switch and it immediately blew. Thinking it could possibly be wires touching on the speaker side I checked those and they're all fine. I then pulled it completely from the system, not hooked up to anything, replaced the fuse, turned it on and it immediately blew again (only power is hooked up to it, nothing else). I pulled the top of the case, looked around and there's no scarring of burn marks, no popped caps, everything looks perfect. I got out my multimeter and checked for continuity in case there was a short somewhere, starting at the speaker terminals and working backwards through the signal path. I couldn't find any shorts at least from what I could tell.
So at this point I'm stuck, I'm hoping someone with more electronics experience can possibly help? Maybe someone that knows something that happened with these amps that may cause that? I've also got another one that intermittently will stop working but a disconnect of all connections, reconnect and power back up and its fine. I'm a bit stumped and hoping someone can help.
Thanks!
Scott
Thanks!
Scott
