FWIW, I'm looking to drive two early-model UFW-10's with an outboard power amp..
I have an opportunity to buy a used Crate SPA-2000 power amp. Specs are below.. it's been used as a demo amp for years at a local pro audio shop and when I asked them if they ever have any old powerful amps come through that I could use for a sub amp he said, "we have a boat anchor that you can make an offer on.."
Spending about an hour online searching doesn't turn up a whole lot.. The user manual (found here) indicates the fan is variable speed, but it'll go in a closed cabinet under the stairs anyway, so unless it's horribly loud, I doubt that's much of a concern (and I could change out the fans anyway, I'm sure)..
Certainly seems to be enough power, I just don't know if it's "good" (clarity/separation/etc) power.
Any thoughts?
thanks,
..dane
POWER OUTPUT
1150 Watts RMS @ 4 ohms, each channel, stereo
2000 Watts RMS @ 8 ohms, bridged mono
750 Watts RMS @ 8 ohms, each channel, stereo
FREQUENCY RESPONSE
+/-.35dB, 20Hz – 20kHz @ full rated power
TOTAL HARMONIC DISTORTION
Less than .006%, 20Hz – 20kHz
Typical .02% @ 1kHz
INTERMODULATION DISTORTION
Less than .05% @ 300W / 4 ohms
SLEW RATE
20 volts per nanosecond
SIGNAL TO NOISE RATIO
Greater than -101dB
INPUT TYPE AND IMPEDANCE
Transformerless electronically balanced, 20k actual load impedance.
Suitable for Low or High-Z balanced line. 3 pin “XLR†plus
3 conductor 1/4†phone jack input per channel.
INPUT SENSITIVITY
1.0 V RMS
LOAD IMPEDANCE
Stereo Mode: 4 ohms or greater
Bridged Mono Mode: 8 ohms or greater
OUTPUT CONNECTIONS
Speakon® jacks, 5-way binding posts each channel
PROTECTION CIRCUITRY
Short circuit, RF burnout, overtemp, speaker protection relays,
turn on/off transient protection, DC protection and built-in
auto-limiter (Anti-clip)
COOLING Forced air fan cooling, rear intake, front and side exhaust
POWER REQUIREMENTS
DOMESTIC: 115 VAC 60Hz, 575VA
EXPORT: 230 VAC 50Hz, 575VA
SIZE AND WEIGHT
19†W x 5.25†H x 16.5†D; 79 lbs.
FREQUENCY RESPONSE
Typical .02% @ 1kHz
SLEW RATE
Greater than -101dB
INPUT SENSITIVITY
1.0 V RMS
LOAD IMPEDANCE
OUTPUT CONNECTIONS
POWER REQUIREMENTS
SIZE AND WEIGHT
thanks,
..dane
