Hello!
Recently my Gizmo amp has had some issues with the right channel output...the cable must be at a certain angle in order for sound to come out, and if it gets jostled around I have to redo the angle.
Not really an issue, since the amp stays stationary and doesn't move that much, but I've noticed that the right channel sounds a bit quieter sometimes, so I did a quick A/B test using frequencies on the Focal Labs Tools CD, and found the right speaker to be softer in the 1.25khz, 2.5khz, 5khz, and 10khz frequencies.
Anyone have a suggestion to this problem?
Thanks!
Thanks!
