T/S parameters
  • T/S parameters
    what do they mean?
    Here is a guide via HTS that gives explanations of the Thiele/Small Parameters and what is favorable when picking out your driver for DIY projects.
    T/S
    Very good reference.
    Have you tried out WinISD yet? I tried once, couldn't find the right parameters of a well know driver, and quickly gave up.
      Michael just sent me the dlink and some parameters to load.
      Going to start modeling some stuff. I need to quit asking others all the time....I'm sure it gets annoying.
        I would try to cut and paste the image of the Quad MFW-15s for example that are currently in my HT against say Quad Mach 5 Pi-18 drivers.
        Not sure, other than downloading WinISD Pro at work and using Snag It there, of pasting the image or attaching it.
        Oh well!
          You need to use the Windows 7 Snipping Tool . . . unless you are using your laptop.
