Just saw this at Emotiva site:
Emotiva mini-X a-100 Stereo Flex Amp
Link
Price: $219
Holiday Sale Price: $199
+ FREE shipping (within continental US)
Might be good for desktop or auxiliary systems.
Link
Price: $219
- Best-in-class design and sound quality. The mini-X a-100 shares the same superior, fully discrete design and high-quality parts as our big ampifiers, so it performs "like the big boys" and sounds far better than most amps in its price and power class.
- 60 watts / channel @ 8 ohms ( 80 watts / channel @ 4 ohms) of stable, great sounding power - sufficient to drive most speakers to satisfying listening levels.
- Flexible turn on. The a-100 can be configured to switch on when an external trigger is received or when it senses audio signal on its inputs. The a-100's Trigger Output can be used to control other components.
- Front panel volume control - allows you to use the a-100 with fixed-level sources, or as a standalone "integrated" amplifier.
- Heavy duty power supply with massive toroidal transformer – provides plenty of continuous power to drive even low efficiency speakers, and enough dynamic power to effortlessly reproduce musical peaks without strain or distortion.
- Compact size and temperature activated forced air cooling allows the amp to be located almost anywhere.
- Buffered loop output - allows you to endlessley daisy chain more amplifiers.
Full sized gold-plated 5-way binding posts make it easy to attach heavy guage wires, lugs, or banana plugs.
- Front panel status indicator. The a-100's Volume knob is surrounded by an illuminated ring, which indicates both Power and Fault status while the position of the knob is highlighted by a pinpoint light on the knob itself.
User selectable AC line voltage; 115 VAC or 230 VAC.
