Rocket RS 850 midrange replacement
  • Rocket RS 850 midrange replacement
    Hello,
    So I've come to solicit some advice on a blown midrange driver for a Rocket RS 850. It appears it is no longer possible to find an exact replacement driver, so I've been looking at alternative options. The original was a 4" aluminum driver.
    Would I be able to install something like this: http://www.parts-express.com/pe/show...number=264-890?
    The description says: "Tang Band W4-1805S 4" Neodymium Midrange Driver
    This compact driver features a self-shielding neodymium magnet system, flat aluminum sandwich cone, integrated protective screen, truncated frame, and extremely low second and third order distortion. The Tang Band W4-1805S is intended for full range use as well as dedicated midrange, with very wide dispersion characteristics.
    Specifications: • Power handling: 35 watts RMS/70 watts max • VCdia: 1-1/2" • Impedance: 6 ohms • Re: 5.6 ohms • Frequency range: 80-8,500 Hz • Fs: 80 Hz • SPL: 90 dB 1W/1m • Vas: 0.2 cu. ft. • Qms: 1.29 • Qes: 0.29 • Qts: 0.24 • Xmax: 0.45 mm • Dimensions: Overall diameter: 4.26" across flats, 4.94" overall, Cutout diameter: 3.8", Depth: 2.36"."
    Also, if this turns out to be a suitable replacement, would I have to replace the other midrange drivers as well to keep them tonally similar? Thank you in advance for your input!
    Did you talk to Hugh or Danny? They actually might be able to get you replacement drivers. Let me know if you need contact info.
    Scott
      Thanks Mr. AH.
      I'm actually working on assigning one of our guys to be the central distribution for all Rockets & Reference drivers since I don't really have time to do it.
      Scott
      Hugh
      MELODY US Distributor
      www.angelcityaudio.com
      A man is only as good as his words.
        Oh cool. I think having support for old AV123 products is a great idea. There's so much product out there with no support anymore.
        Scott
          Thanks Mr. AH. :)
          Scott
          Hugh
            Hey, I remember both of you from the old AV123 forums! That'd be awesome, Hugh, if you're going to have an option for the original drivers. Any idea when that might come into fruition? Or any say on what dropping in another similar midrange would sound like? Thanks again.
              I remember you too. :)
              I'm working on assigning one of our guys to be the central figure to provide support for all drivers, be it Rockets or Refs.
              These will be original drivers.
              Stay tuned.
              Hugh
                Thought that was ME ???
                Stay tuned.
                  Did you p*ss him off?
                  :biglaugh:
                    Stay tuned.
                    Will this include the Rocket 450's too? I have been searching for a driver for a Rocket 450 speaker. All I need is one, I hope you guys can help me out. Where can I find out more?
                      Yes it will.
                      More news after the Holidays over. :)
                      Hugh
                        Yes it will.
                        Great news! Thank you!
                          Until further notice, email me for our needs.
                          Also, I can only furnish drivers as pair(s) and not a single one.
                          Moreover, if you still have your Refs speakers, you'd better hold on to those since the Atohm woofers are not cheap.
                          Hugh
                            For the rocket line I still have available
                            RS850/1000 5.25" Woofers
                            SRC200 Bigfoot I still have the 6.5" woofers.
                            I dont have a lot of either of the woofers left though.
                            I have the Vifa tweeters for most all of the Rocket and Onix REF line.
                            Strata Mini's I do have tweeters and also the powered woofers, although the tweeters are in VERY short supply.
                              If you're in need of any drivers in Kevin's stocks, get those first.
                              Hugh
