Changing speakers
  • Changing speakers
    Recent events in my life have forced me to come to the realization that my current speakers won't work in my new environment. In short, I moved, started to set up the speakers, and then the "oh crap" realization kicked in. :doh! 1:
    Currently, I have Rocket 550s, 150s, Bigfoot, and their accompanying 10" sub. Overall, not too bad of a setup.
    Now for the problems. The couch must be on the far right wall of the, roughly, 8' x 13' open living room. That is per the wife for appearance rather than for sound. Can't say I blame her, especially as a couch in the entryway really messes up the flow of the house. This also means the right main speaker would now be blocking the A/C filter/vent.
    Second, did I forget to mention the front wall is actually a hair over 7' with a wall mounted TV that takes up 4' of that available space? And the wall studs are 2' apart? Mounting them might be a little bit of a challenge.
    Final problem. The rear of the room, typically where the surrounds/rears would go, is nicely framed in. By a bay window. Needless to say, the love seat is now occupying that location and is not going anywhere. So my options here are limited to either small or in-ceiling speakers.
    Floor standing main speakers have been ruled out and I would like to upgrade my sub at some point. My budget can be flexible as I would not rule out going slowly rather than upgrading all at once, amazingly enough starting with the rears.
    So, as you can see, I need help and greatly appreciate all the help all of you can offer. :)
    So, are you looking to do in-ceilings for the rears and bookshelves for the fronts? Do you plan on keeping the bigfoot, or is it too big?
    Time waits for no man.
      :pics:
        Well, here's a couple leads on nice quality budget in-ceiling speakers.
        Welcome to Emotiva Audio Corporation. Home Audio Systems, Speakers & Accessories and more. We use science to evoke the true emotion behind every note.
        They are both a good value imo.
          I have the HTD in walls / in ceilings in my living room and master bedroom, and have been quite happy with them (but I generally don't either very hard - that's what the dedicated HT is for).
          If I was going for a more serious, dedicated room, I'd probably look at the Hsu in-walls. I've auditioned them, they sound great, and can play pretty loud. Same design as their bookshelves (minus the box). Triads also come highly recommended - but at a price.
          Edit: depending on your size limitations, the Hsu bookshelves might work as well, quite a bit smaller than the CHT bookshelves for example.
            I'm not sure if these are still available as a kit, but know the C-4 is. I used one of these for quite some time before buying my current center, and it is big sound from a small enclosure. I can't speak for the smaller MM-4 as I haven't heard it, but the C-4 provides room filling sound. I would imagine a 5.1 setup with these would be plenty for your room.
            Pics I have no affiliation with this company, just found the pictures here on a google search.
            I purchased a second C-4 with plans to re purpose them as surrounds. I bought mine on ebay for less than $100 each. They have aluminum drivers, so they should work fine with your existing sub, assuming you have room for it.
            Are the Chase products to large for consideration?
              If you're thinking in ceilings or inwalls then definitely have a look at def tech! Mine sound better then a few floor standing speakers I've heard. Axiom's and various Klipsch's and Polk's.
                Is this the BryanZ who used to own nOrh 4.0s?
                  That's a tough one. I couldn't part with my Rocket RS850s when I went with an acoustic screen in my HT. So I kicked my Paradigms out of the living room and moved the Rockets in...thankfully my wife loves the way they blend in with the decor.:woo: although I have no center (bigfoot is in the closet) no room for it with a wall mounted plasma. but it still sounds great.
                  I'd go for two channel in-wall before i did R/C/L in the ceiling. They're easy to install and as long as you have attic room to get to the walls top plate running wires is a breeze.
                  For surrounds inwalls are still better location wise but in ceiling is ok. I use in ceiling surrounds in my living room (17' ceiling) but I never watch movies in there so I don't really consider it a HT setup...just a nice TV watching Setup with top notch sound.
                  You can only do what your room and the misses will allow!:)
