searchin for an amp or receiver
  • searchin for an amp or receiver
    Hello CHT memebers. New here. Was informed by youra6 to sign up.
    Anyways i bought so wafs off him and now i am lookin for an amp.
    Some preferences is that i need a amp thag has a line in if possible and another port to add a sub later. Or have a sub input.
    I would like it not to be super heavy and taking up a lot of space and budget friendly if possible.
    Thanks fellow members hoping you guys can point me in the right direction
    :Welcome: to the forum.
    It would be helpful if we had a rough idea of budget limits. Also helpful would be a rough idea of how loud you like to listen, how far you will be sitting from the speakers, and whether you want a surround receiver (AV receiver) or a stereo receiver.
      Welcome JAMM0N,
      Are you looking for a desktop solution? If so, have a look through this thread. http://www.chasehometheater.com/foru...ead.php?t=3777
        so an amp that i got a quote from was 90 dollars. which is okay but i might as well drop a little extra.
        i sit close to my speakers ATM but they'll be on the floor or on the shelf as i have no space.
        i would like to prep for the future more than now but i dont want to lug something too heavy around. the speakers are already about 20 pounds. i plan on taking these home w/ me when i'm done living in this forsaken state
        Onkyo TX-SR705?
        Harman Kardon HK-3490?
          Onkyo TX-SR705?
          Those are two very different receivers. One is a stereo only, the other is for Home Theater but can be used for 2 channel. They are both pretty heavy, but quality usually is.
          1. What are you future applications going to be, 2 channel only or HT?
          2. Are these choices new?
          3. What are the differences in price?
            i do a bit of everything.
            yeah both are going to be heavy and hot when under use.
            i'm planning to upgrade to 5.1 if possible. 7.1 when i have my own place to myself.
            these choices are what i can find for now that are within budget.
            the onkyo is like $175 shipped
            the harmon is like $220 shipped
            i'm hoping to get better deals.
            i'm also looking @ a sub a Paradigm Subwoofer PS-1000V3 for about <~200
              For future home theater applications, the Harmon Kardon is out, then. It is a wonderful receiver, I just recommended one to my neighbor and he loves it. But you want to expand so that strikes the H/K from consideration.
              The Onkyo is also less expensive. I do not know much about this unit, but from reading it seems to be a decent budget piece.
                The Onkyo is a great receiver! :D Check this thread:
                Onkyo TX SR705: FAQ This FAQ was last updated on: 12/11/08 [For full change log, refer to the bottom of post #2] Click for a Large Image of the Front Panel of the receiver. Click for a Large Image of the Back Panel of the receiver. › Click Here to view the TX SR705 details on...
                -I live in Madison, WI (what a boring sig right? :))
                  Holy cow, no thanks! We'll let JAMM0N plow through that thread.
                    Jamon Leeeeee JAMMON :biglaugh::biglaugh:
                      Well I meant to quote the OP, so I see why you were confused. lol
                        holy crap that is a lot. still waiting to see.
                        here are some other options i found that are local. i know i need to do a lot more research on receivers. but right now just browsing
                        Yamaha RX-V659BL
                        Yamaha RX-V1500
                        or just recommended me one for $150-200
                          Two channel only, the H/K all the way. They also have great HT receivers but I think that Onkyo and Marantz are a better value feature wise.
                          It won't get any cheaper than this place. They sell a lot of refurbs, but I haven't seen any complaints. This place has a good reputation.
                          Marantz, Yamaha, KEF, Focal, Polk, Def Tech, Denon, Home Theater, Speakers, Receivers, HDMI
                          Look around in our classified section for deals, too.
                            your classifieds are around my budget area if i could grab one.
                            i might go with the onkyo if the guy is local if not. i'll look @ others.
                            h/K is about $220 debating debating
                              So far using a technica receiver for audio too bad no line in could use it
