Guys-
Have a neighbor that is building a HT.
He is considering mating these subs with SHO10s at the moment.
He may make his false wall <20 inches from his foundation, so he may not be in play for the SS 18.2/1 series.
Currently we are thinking what would a DTS10kit + the Growler Duo mesh together like?
DTS 10(s) behind the screen with a Growler Duo or other considerations in a few wall niches he has room for in his build.
If you had a Behringer DCX2496 or MiniDSP to EQ, would that be a pretty lethal combination?
I think he realizes the DTS10 is great up to about 45 hz, but then the distortion and resonance problems start up....so I was thinking of ways to help him out.
Any ideas? I'm going over there today to check out his layout so I can get a better feel from it for recommendations. I'm going to try and get him to make his false wall deeper so he can consider multiple sealed as well....
I'll get the space info and budget numbers as well.
