Gizmo desktop amp alternatives
  • Gizmo desktop amp alternatives
    The Gizmo desktop amplifier (old thread - X-19) has been discontinued and sold out (12/15/10 link).
    Recently people have expressed interest in that type of mini-desktop integrated amp and other electronics (link1, 12/15/10 link)"]link2[/URL]).
    I bought a few of the Gizmos and found them highly useful for setting up work audio systems.
    I thought I'd explore and post some alternatives.
    Features:
    - small
    - "inexpensive" -- although that may vary
    - +/- subwoofer output (may use full range speaker outputs and then "sat" output from subwoofer -- if available)
    Please post if you have any experience with these, note other important features, etc.
    Updated: 1-4-2011
    Purple = DIY kit
    Red = explicit subwoofer output (not just full range to sub then crossover in subwoofer)
    Audioengine
    - Audioengine N22 - $199 - 22W/ch, 2 inputs, headphone out
    Class D Audio (DIY)
    - SDS-224 DIY Kit - $275 - 120w @ 4ohm, 60w @ 8ohm
    - SDS-254 DIY Kit - $310 - 250w @ 4ohm, 125w @ 8ohm
    - SDS-258 DIY Kit - $360 - 250w @ 8ohms (please check with class D for 4ohm)
    Dayton
    - DTA-100a - $99 - Class-T Digital Amplifier 50W/ch (into 8 ohms @ 3% THD), 2 x 30 watts RMS (into 8 ohms @ 0.01% THD)
    - DTA-1 - $34 - Class T Digital AC/DC Amp - 15W/ch RMS (into 4 ohms @ 10% THD), 10W/ch RMS (into 4 ohms @ 0.1% THD)
    - Dayton APA150 - $159 - 75W/ch RMS (into 4 ohms @ less than 0.01% THD), low pass filter
    HifimeDiy (DIY)
    Link
    Lepai
    - Tripath TA2020 - $20 - Class-T - 2 x 20 watts RMS * Minimum THD : <0.05%
    Maverick Audio
    - TubeMagic A1 - $199 - "power amplifier, a tube headphone amplifier and a tube pre-amplifier" - 20W/ch, Class A/B
    - TubeMagic D1 DAC - $199 - DAC (not an amp) can be used with A1 amp
    NuForce
    - Icon amp - $189 - 2x24W amp
    - Icon - $249 - 2x12W amp - subwoofer line out
    - Icon2 - $349 - 2x24W amp
    - NuForce Icon HDP - $449 - Headphone Amp, DAC and Preamp
    Pyle-Pro
    - PCAU22 - $47 - 40W/ch (4ohm, unspecified distortion) Amp w/ USB Input
    - PTA2 Mini - $60 - 8Wch (1 kHz @4ohms, 1% THD) Stereo Mixer/Power Amplifier
    - PCA3 - $69 - 15W/ch @ 1%THD, bass/treble controls
    - PTA3 - $67 - 15W/ch @ 1%THD, 3 inputs, bass/treble controls
    Trends Audio
    - Trends TA-10.1 - $179 - Mini Class-T Stereo Amplifier - 10W/ch (8ohm)
    Virtue Audio
    - One.2 "Classic" - $299 - 87 wpc @ 4 ohms - subwoofer pre-out - "...same amplifier as the ONE.2 without the extra set of input caps for bass management and stepped attenuator."
    - One.2 - $349 -
    - Two.2 - $449 -
      If you do not mind going the DIY route consider the ClassD amps:
      http://classdaudio.com/index.php/pro...s-224-kit.html (120w @ 4ohm, 60w @ 8ohm) - $275
      http://classdaudio.com/index.php/pro...s-254-kit.html (250w @ 4ohm, 125w @ 8ohm) - $310
      http://classdaudio.com/index.php/pro...s-258-kit.html (250w @ 8ohms, please check with classd for 4ohm) - $360
      Maverick Audio TubeMagic A1 - http://www.mav-audio.com/base/product/tube_magic_a1 - $199
        Class D Audio kits
        Cool.
        Do the Class D Audio kits have "shells"?
          Gizmo specs
          Gizmo specs (for reference)
          $139 (including shipping) - originally
          Output Connections: L/R channel speakers ; Subwoofer out (RCA connection)
          Power Rating: 25WPC x 2 @ 4 ohms (or 8 ohms ???)
          Voltage: 110V/220V
          Shipping weight: 7 lbs (approx)
          Dimensions: 8"D x 2.5"H x 4.5"W
          Additional Features:
          • Digital Display
          • Separate Bass and Treble Controls
          • Subwoofer out
          • Rosewood cap
          • True 100 Hz crossover built-in
          • Volume +/-, Mute, Standby and Bass/Treble controls
            Originally posted by Mike_TX
            Cool.
            Sorry, can you clarify what you mean by shells? Do you mean a case. If yes, than the answer is no you have to provide rca jacks, case, speaker connectors and IEC power adapter.
              Yes, case.
              Thanks
                Yes, case.
                Thanks
                My total build cost for the cda254L amp kit/case/rca/iec/speaker was around 330 or so. Thinking about building 500w mono amps.
                  500 W mono amps!
                  Cool.
                  Start a build thread if you do.
                  I'm sure people will be interested.
                  BTW - you might consider posting your gear in your signature, so people can see what you are combining.
                  Cheers,
                    OR
                    OR
                    a little ugly, but: http://tinyurl.com/27b4uvq
                    With that wattage, the voice coil is now a Rail Gun. You get 1 note, but it will be memorable! :salute:
                    Stolen from JEFFakaMAX at AVSforum.
                      Thanks.
                      N22 was mentioned above.
                      I added the others to the list.
                        Some more:
                        Dayton DTA-100a based around Tripath Chipset 50w @ 8ohms
                        Dayton DTA-1
                          Don't forget the virtue One.2 and Two.2.
                          For DIY another tripath option is hifimediy.
                            The Dayton DTA-100a also functions as a headphone amp
                            "The DTA-100a also doubles as a high fidelity headphone amplifier that will drive any headphone easily, and delivers colossal sound stage and effortless dynamic range."
                            Here's a few others
                            Lepai Tripath TA2020 Class-T Hi-Fi Audio Amplifier
                            Pyle Pro PCA2 Mini Stereo Power Amplifier
                            Pyle Pro PCA3 Mini Stereo Power Amplifier
                            This ones a little larger
                            Dayton APA150 150W Power Amplifier
                              I've been doing a little digging on my own, and came across the Pyle Pro PTA2 Mini 2x40W Stereo Mixer/Power Amplifier.
                              It's at a pretty decent price point between the DTA-100a and DTA-1, plus it has input switching which is also nice. I'm a little worried about complaints of hissing from the reviews, as I'd be listening via WAF-1s or Audio Technica ATH-ES7s from onboard PC output, an iPod Classic, or a Playstation 3.
