Thread for Inexpensive Receiver/Amp Options
  • Thread for Inexpensive Receiver/Amp Options
    Hi guys...
    I think we should form a thread with suggestions for inexpensive electronics for which to pair some of these awesome budget speaker offerings on the market now.
    List some good budget receivers, integrated amps, or whatever else you can find!
    I'll start, I love the basic Pioneer (non-elite) receivers. For the money, a lot of features, great sound quality, and they seem pretty reliable. The chipamp models (I believe they start at either the 8xx or 9xx models) have extremely low crossover distortion and tested very well by Dr. Earl Geddes.
    Another great option for a budget system I found was the First Watt F5 clones. They are only 25 WPC and require a pre (or passive attenuators which can be had for pretty cheap), but the sound quality is to die for.
    As a DIY option, the Class D audio amps are supposed to be excellent! When I get some extra dough, I hope to own one myself.
    -Bill Watterson
    Good idea.
    Likely this should be under:
    Audio Gear from Other Companies
    ...I think "Electronics" means CHT electronics.
    :crazy:
      I guess everyone has to interpret what "inexpensive" means to them in their own context - I'm with you, I liked the feature set of the non-Elite Pioneer receivers, and bought an 1120K, and I'm enjoying it thus far - although the sheer number of options available can be befuddling at times (accidentally hit the wrong remote button without noticing, and spend a while trying to figure why it isn't working the way you want it to).
        Inexpensive meaning high value or low price (as low as we can possibly go upto a thousand dollars). You can represent good value at just about any pricepoint, I'd like people to post about the amplification they've used which represents great bang for the buck.
        I would think electronics section works as this is specifically related to electronics/amplification and CHT no longer sells anything but the discontinued Gizmo in this category.
        The less we have to spend on amplification, the more we can spend on new speakers "thumbsup:
        -Bill Watterson
          I have bought a couple of refurb H/K for under $200. They put out a decent amount of power but lack a good room correction option.
            And with higher sensitivity speakers, you'll need to spend less on amplification "thumbsup:
              Exposure 2010S
              I caught one of these at a local dealer, was a demo model. I love the passive pre section, a very transparent amplifier.
              Retail is $1395, I snagged it for $600 w/ factory warranty.
              Yet another of the best systems I've ever heard at a hi-fi show was an exhibit by some former distributors for the English manufacturer Exposure Electronics, at a Chicago Consumer Electronics Show in the late 1980s.
              • High capacity, 200VA custom-made toroidal power transformer and power supply capacitors.
              • Improved all-aluminum casework and extruded front panel to control resonance and stray electro-magnetic fields.
              • High quality capacitors used in the signal path.
              • Uniquely tuned short signal and power supply path PCB.
              • Cascode circuitry utilized for improved power supply immunity.
              • Sanken bipolar output transistors.
              • Separate pre-amp output with class A buffer stage.
              • 75 watts per channel into 8 ohms.
              • Full system remote control.
              • Three year guarantee.
                Onkyo Rc180
                No 3D, but if your not interested in that... it has alot going for it at the price point.
                Time waits for no man.
                  Well ... assuming it doesn't have to be "new" and you're going for inexpensive, what about the old Marantz low powered receivers? Like this 2240 that's on Audiogon right now for $150:
                  You couple it with some very highly efficient speakers and you've got a killer 2 channel setup!
                  EDIT: JUST FOUND OUT WHAT THE "QUAD" STEREO THING WAS ALL ABOUT. WOULDN'T DO THIS AMP BUT STILL, GOOD OLD MARANTZ'S ARE OUT THERE FOR LITTLE $$$ IF THEY'RE THE LOW POWER VERSIONS.
                    Originally posted by Mike_TX
                    Good idea.
                    :crazy:
                    Moved.
                      Emotiva UPA-5 amp - $429 - 125W x5
                      Great deal on an amp to partner with an AVR (was on backorder, now on sale):
                      Emotiva UPA-5
                      Five Channel Audio Power Amplifier
                      125 watts RMS x 5 into 8 ohms
                      185 watts RMS x 5 into 4 ohms
                      $429 + free S/H
                      Link
                      UPA-7 = $599
