A few years ago I added a layer of R-25 to our attic and it has made a dramatic difference. In the coming months I am going to re-insulate our vented crawl space.
Our crawl space is at the lowest a little over four feet and at the highest point around six and a half feet. The joists have metal cross bracing and the builder installed faced R-13 but instead of having the facing flat against the bottom of the sub-floor they simply hopped over the cross bracing. From what I've read this is not ideal and the facing should be tight against the sub floor so I plan to correct this and then fill the remaining cavity with additional unfaced insulation.
One of my concerns is that I installed 3/4" hardwood several years ago on 75% of the first floor. Due to this there are numerous cleats sticking out of the bottom of the sub-floor.
Is there a work around to this or should I not worry if the facing is punctured? I did use 30lb roofing felt on top of the sub-floor while installing the floor and sealed all the seams with duct tape.
Opinions/suggestions would be appreciated.
