1" 15 ply birch plywood for speaker box
  • 1" 15 ply birch plywood for speaker box
    1" 15 ply birch plywood for speaker box.
    Overkill or just right?
    Just right.
      If some if good, more is better and too much is just enough! :mr-t:
      "The evil that men do lives after them; The good is oft interred with their bones."
        overkill = just right
          walls will be one inch thick? naw not overkill.
          depends on how much bracing you do ;)
          matrix style bracing with carbon fiber wrapped over it, then yeah maybe overkill. but damn cool at the same time! :brainiac:
          Matt
