Wanted to pass along the results of playing w/ Mortite (aka Frost King Fingertip Rope Caulk from Lowes) w/ my Mini's. One thing that I have noticed for a while about the Mini's is that the sounds tended to blur somewhat. The speed of the attack and the decay just weren't as good as I'd have hoped, and in this area as well as in microdynamics, the Mini's were easily surpassed by my Dali Mentor Menuet monitors. So, I started to try to figure out what I could do about it. I noticed that the baffles for the planar drivers tended to shake quite a bit. Turned out that this was due to the Mid-Bass Coupler (MBC) and not the powered woofer (that cabinet had already been treated w/ No Rez from my Ninja mod upgrade). So, I went about trying to reduce the vibration, which I felt could be the cause of the smearing of the sound. Adding No Rez to the MBC cabinet area didn't help. Seemed to have resulted in a hole in the midbass. Frustrated, I tried to figure out what I could do.
One thing my Mentor Menuets do is decouple the drivers from the cabinet. So, I looked to see how I could do the same thing w/ the Mini's. Turns out that people have been using the Mortite, which is something like BluTak, to decouple of the drivers. Figuring, what the heck, I can always take it off if I need to, I tried it out first w/ the MBC, then the planars, and finally the powered woofers. Turns out that the stuff is pretty easy to use and works as hoped. The speed of the attack and decay for the Mini's is now better, there's less smearing, and the dynamics (both micro and macro) are better. Still not quite at the level of my Mentor Menuets (which are amongst the best I've heard in these areas), but now the Mini's aren't put to shame.
Overall, not 1/2 bad for a cheap tweak, <$6, for a box. Will have to try it with some of the other speakers I have.
