Alrighty...finally got REW up and running and I'm having some problems with Audyssey that I could use some help from the pros with.
5.1 Setup -
3808ci - Fully updated, all options
Fronts - JBL - L890s
Center - Old JBL - SC305
Backs - Old JBL - G200s
Subs - 2x18.2s
First problem I'm having is that if I turn the gain on the 18.2s to more than the 8 o'clock position Audyssey sets them to -12db. At the 8 o'clock position I finally got it to set the subs at -10db. Once calibrated I watched a movie and it felt like I had no bass...turned the gain back up to the 12 o'clock position and the earth shook again. Is there a setting I'm missing so that I can run the subs hot? I calibrated them at 0db boost and it still felt weak even with the 15db boost turned on with the gain down so low. Is there some way to change the -10db Audyssey is applying somewhere other than the 5/10/15db boost setting?
Next problem is Audyssey keeps setting my fronts to large. I have the receiver crossover set at 80hz for all speakers other than the subs which I have at 120hz.
Lastly, when I run REW I have about a 10db null at around 60hz...then I looked at the audyssey eq settings and it had 60hz set at ~ -10db. Grrrrrr...I liked how it adjusted everything else but I definitely want to correct that. Is there a way on the 3808 to manually adjust the audyssey equilization?
I know these are beginner noob questions. I've been reading all night but nothing quite matches up to the problems I'm having. Any help at all would be appreciated (even if it is taunting that shows what I should be typing into search to find my answers)!
5.1 Setup -
Subs - 2x18.2s
