Audyssey MultEQ XT 32
  • Audyssey MultEQ XT 32
    FYI from AVS...
    Link
    Chris/Audyssey:
    MultEQ XT 32 is a major new development in the MultEQ algorithm since the original release in 2004. It has been 2+ years in the making and the result of countless hours of algorithm development and some new math.
    Using multiple sampling rates in the measurement and filter synthesis process we derived a method that increases the resolution of the MultEQ XT filters by a factor of 32 from what we have today. That gives it many thousands of individual control points with which to shape the response that it measures so that it can achieve the desired response.
    Link
    I should have been a little more clear: MultEQ XT 32 will increase the resolution of the main channels from 16x to 512x and the resolution of the subwoofer from 128x to 512x. So, all channels will have the same 512x resolution.
    Link
    Sorry.. I added to the resolution confusion because I forgot about the firmware upgrade that doubled the resolution of the Subwoofer Equalizer and the AS-EQ1 months ago. So, the correct numbers are:
    MultEQ
    Sats: 2x Sub: 128x
    MultEQ XT:
    Sats: 16x Sub: 128x
    MultEQ XT on Sound EQ
    Sats: 32x Sub: 256x
    MultEQ XT 32
    Sats: 512x Sub: 512x
    MultEQ XT on Sub EQ
    Sats: N/A Sub: 512x
