Gonk, Help!
  • Gonk, Help!
    While playing a CD in my Oppo BDP-83 SE, the music suddenly cut off and a buzzing noise came from the Oppo. I shut it off and on the restart it sounded fine ... for two minutes, then failed again. On the next try (with a different disk), the disk would not load.
    After a complete power down, the unit seemed normal ... for four minutes. Then the music cut off and the Oppo began making buzzing noises. I fear the laser has crapped out. But I see there have been some firmware upgrades. Any chance this is a known glitch that a firmware upgrade would fix?
    Randy
    Now it won't recognize Blu-ray disks. :crazy:
    Randy
      This is not something I've heard about, certainly not related to a firmware issue. If you haven't done so already, I'd recommend resetting the player to the defaults. If that doesn't work, I'd contact OPPO. Email them this weekend - that'll put you near the front of the line for help, and you might even get a response this weekend.
        They did respond, which pleasantly surprised me. I upgraded the firmware and did a reset, but it did not help. It will not load properly, will not recognize a CD or a DVD, or play back. I think there is a mechanical failure. It's going back. I am sure Oppo will make it right (it's still under warranty).
        Randy
          Oppo stepped up. Fixed the defective power supply under warranty and even covered shipping both ways. working great now.
          Randy
            Glad to hear that it's sorted out.
