OK, I decided my 2.5 watt MiniWatt amp needs a little more oomph down low. Solution? Build bigger baffles and add 15" Hawthorne Audio Augies and a Dayton plate amp! That should just about do it!!! My project may take a little while to finish, but I've made a good start already:
New Stuff I'm Building...
Tweak City Audio WAF-1, Paradigm PS1000, Jolida FX-10 tube amp, Samsung Blu-ray, Beresford TC-7520 DAC, Apple Airport Express (living room)
Other stuff: Usher S-520, JohnBlue JB-3, MiniWatt, Glow Amp One, Nuforce Icon Mobile, Sennheiser HD595Tags: None
Originally posted by django1Nice circles! What kind of a jig did you use on the router?
I made a circle jig out of a piece of lexan. Just drill and countersink the holes for the mounting screws and you're in business. Measure from the edge of the bit to whatever radius you need and drill a hole in the lexan for the pivot point. Works great for cutting multiple holes of the same size. Not so much when you have a bunch of different size circles. You end up with a lot of holes in the lexan and it gets to be a pain. Buy, hey.....I'm cheap.
Sure, but with shipping back and forth to Canada I think it would be cheaper for me to just buy you one. :D
BTW, the one I got was stocked by Amazon with free shipping, but I also noticed that for products offered by PartsExpress via the amazon storefront the shipping was cheaper than ordering directly from PartsExpress.
Originally posted by django1Can I borrow it:eyebrows:?
Here is the "plan" for the baffles and a photo of one of the base boxes being built. I'm pretty covered up at work and at home so it has been a task to find the time to put into this little project. I had hoped to have them finished in April but now I'm hoping for May. Oh, and I don't profess to be a woodworking craftsman...this is my first DIY project and I'm learning as I go!Tweak City Audio WAF-1, Paradigm PS1000, Jolida FX-10 tube amp, Samsung Blu-ray, Beresford TC-7520 DAC, Apple Airport Express (living room)
Test fitted one of the OB's this evening! Perhaps not the finest craftsmanship (see Lead Suspect for that!!!) but playing one unfinished with a mono Augie and the other speaker in a temporary baffle, it was everything I had hoped for and well worth the effort (even though I'm only halfway done with the build (and then I have to stain them!). I am learning every step of the way which has been really enjoyable.Tweak City Audio WAF-1, Paradigm PS1000, Jolida FX-10 tube amp, Samsung Blu-ray, Beresford TC-7520 DAC, Apple Airport Express (living room)
FINALLY got the second baffle built and it is being test fitted so I'm finally stereo with two 10" drivers/compression tweaters and two bass augmenters.
I am extremely pleased with how musical, detailed, and fast paced the Hawthorne's are...and the Augies really fill in a solid foundation. The sound stage/imaging are a treat to experience! I couldn't be happier with the progress this project is making!Tweak City Audio WAF-1, Paradigm PS1000, Jolida FX-10 tube amp, Samsung Blu-ray, Beresford TC-7520 DAC, Apple Airport Express (living room)
Congrats on the finished products. They look really nice. I may have to drop by for a demo :)PhenomeNhan Audio Video
[email protected]
