Updated: 12-13-10
PRODUCT PAGE SPECS:
Link
Signal-to-Noise Ratio: > 105dB (A-Weighted)
Frequency Response: 5Hz - 48kHz
THD+N: 0.001%
Ground Floor Noise Level: < 15uV
Nominal Output Voltage: 1V RMS
Peak Output Voltage: > 12VRMS (balanced)
Sample Rate: All standard resolutions are supported up to 192kHz
Bit Depth: Standard bit depths up to 24Bit are supported at clock frequencies up to 192kHz
Inputs: 2 Optical TOSLINK, 2 COAX Digital, 1 AES/EBU, 1 USB
Outputs: 2 RCA (Unbalanced), 2 XLR (Balanced)
Internal Volume Control: Digitally controlled in increments of 0.5db
Remote Control: Milled Aluminum Full Function Remote Control
I/V conversion: Burr Brown OPA-2134
D/A conversion: high performance, multibit Sigma-Delta Burr Brown AD1955
Data Directed Scrambling with high jitter immunity, and an 8x Oversampling Digital Filter
Fully Discrete Differential Reference™ Output Stage with fully independent balanced and unbalanced drive stages
Latest pics and specs on XDA-1
6-10-10 update (Emotiva VIP Lounge): Link
"Some quick specs for you all.
Frequency response: 5-50Khz
S/N: in excess of 110db
THD+N: 0.02%
Ground floor noise: 10uV
Output voltage: 1V nominal, 12V peak"
"We hope to have them in your hands in about 45 days."
Q (TonyMc): "So would putting the XDA-1 between transport and USP-1 negate the sonic improvements of the XDA-1?"
A (Lonnie): "It won't negate the improved sound, but as good as the line stage is in the USP, the XDA by itself is way better."
*UPDATE*
5-18-10
New pic available (see below).
New specs coming in days
4/2/10 Post - LINK -
"They announced in today's webcast
(section 2 of the webcast)
that the new physical design on the DAC means it won't be released for another 90 days or so.
So at this point, the DAC should be available sometime this July."[/B][/COLOR]
Emotiva XDA-1 digital-analog converter (DAC)
Cost: $299.00
Specifications:
(pending)
From Emonatics - http://emonatics.com/XDA-1.shtml
(unconfirmed)...
Inputs (both)
1) AES/EBU
2) Coax Digital
2) Optical Digital
1) USB (Should be PC & Mac Compatible)
-- Post: 10-13-10 @ Emotiva Forum (link):
Post: 11-11-10 @ Emotiva Forum (roadrunner) - link
Outputs
1) L/R Unbalanced RCAs
1) L/R Balanced XLRs (all outputs are hgh voltage)
Triggers (automatic on/off for amplifiers and XDA-1 itself)
1) 12v output trigger
1) 12v input trigger
Analog Devices AD1955 DAC, with 384k oversampling, and 1V rms (7V peak for extended dynamics), 24-bit, 192 kHz Sample Rate PCM Audio Data, 120 dB SNR/DNR (not muted) at 48KHz Sample Rate (A-Weighted Stereo), -110 dB THD+N (0.0003162%)
Burr Brown buffers coming out of the DAC
6 fully discrete output stages
Selectable inputs
Segmented power supply
XDA-1 Manual
Features:
- headphone jack
- volume control: digital & global (for all inputs)
--- therefore, turn volume to MAX for use with pre-amp ????
Post at Emotiva Forum (srb):
12-5-10 robdog post
(bold added)
- 6 discrete output stages
- selectable inputs
- segmented power supply
Other info:
- 1 RU high
- old name was XDC-1
- Lonnie (@ Emotiva forum):
"Even though the ERC and XDA share the same DAC, the reason the XDA sounds so much better is because of the discrete output stage.
In the ERC the design is a straight forward single dif, going to a single stage VAS and output stage.
The XDA on the other hand uses a Dual dif input stage with crosslinked current sources, Darlington VAS stage and Darlington output stages, so the speed and current it can deliver is like night and day different from the ERC.
So as good as the ERC sounded (and to be honest I thought it was amazing), the XDA is in a league all its own."
Future:
- "At this time I am just working on this one. The baby version is down the road. "
Links
Emonatics link
XDA-1 bypass mode??? (Emotiva thread by Kiwi) Link - http://emotivalounge.proboards.com/i...d=11034&page=1
--[ORIGINAL POST]--
FYI...
Emotiva XDA-1 DAC update from Admin at Emotiva forum:
Link
Actual pics, specs and pricing coming very soon. just waiting on the cosmetic prototype to arrive.
I have an engineering mule, but it is far from pretty. So if all goes well, maybe in another week I can have them for you.
BTW, I don't know if I actually posted what it really looks like or not so here it is.
Specs are pending but previous comments...
- estimated cost - $300
- 1 RU high
PRODUCT PAGE SPECS:
Link
THD+N: 0.001%
THD+N: 0.02%
*UPDATE*
5-18-10
Cost: $299.00
Specifications:
(pending)
(unconfirmed)...
Inputs (both)
1) AES/EBU
2) Coax Digital
2) Optical Digital
I spoke to Lonnie about this when I was at Emofest. Lonnie sent me to Eric in engineering. Eric told me the USB only supported max. 16/48.
I just got off the phone from speaking with Eric about the XDA-1's USB ports. There has been confusion as to just what the specs for the USB is really capable of handling. Well, now we have the official confirmation from Eric that the XDA-1 DOES handle 24 bit/192 KHz via its USB inputs. Of course it also handles 16/44.1, 16/48, 24/96, etc, etc. It will output whatever you send it without down converting the signal.
Selectable inputs
XDA-1 Manual
Features:
- headphone jack
As has been previously mentioned (and both verified by Emotiva and Analog Devices), the on-chip volume control implementation is an analog resistor ladder, albeit digitally controlled, and doesn't use up bits to attenuate.
(bold added)
I called Emotiva on Friday and asked Vincent that same question.
He said that I should run the XDA at full volume, leaving it at 80, and use the USP-1 to make volume adjustments while listening.
When I mentioned the high gain on the USP-1 he said that the XDA could be set lower if needed, as it was a "lossless" volume control and would not cause any loss of resolution, detail, etc.
So, I have been using the XDA set at about 60 - 70 and I use the USP-1 for volume adjustment.
I do occasionally grab the XDA remote for fine volume adjusments when needed - since one push of the button on the USP-1 remote turns it up or down so much.
Seems to be working well for me that way.
Anyway, based on my conversation with Vincent, I would suggest starting at 80 on the XDA-1 and working down until you find a setting that works best with the USP-1.
- selectable inputs
Other info:
- 1 RU high
Future:
Links
Emonatics link
--[ORIGINAL POST]--
FYI...
Link
- 1 RU high
