On/Off for subs
  • On/Off for subs
    I own 2 ULW's and 1 UFW and would like to save energy while they aren't being used. I realize it's not much but sitting in standby the majority of the time I figure there is something to be saved.
    Aside from turning the isobar they are plugged into (which is nearly impossible to reach) does anybody have a better solution to this?
    Thanks
    Thanks
    You could look at finding a power strip that has a trigger and hook the trigger up to your receiver/prepro and have the strip turn on when the prepro does...
      I see a lot of recommendations for these to solve your problem.
      I have one, and it doesn't work as well as I would like, there is a fair deadband around the on/off for the controlled outlets that causes mine to be finicky. But perhaps if your pre-pro draws more power it would work fine for you.
        Plug your receiver/amp into the power tool switch and then two of the subs into the accessory outlets. Your receiver or amp needs to draw enough power to turn on the accessories (class D/T may not work).
        Shop Sears for appliances, tools, clothing, mattresses & more. Great name brands like Kenmore, Craftsman Tools, Serta, Diehard and many others.
          Thanks for the suggestions. I'm currently using this Tripplite unit and would like to continue to do so. Are all these type units reliant on output current to the amp to trigger the outlets on/off? I seem to recall something I saw in the past that was like a remote control for the outlet.
            Take a look around here, you should be able to find a combination that works for you.
              I intended to reply to this earlier but other projects have kept me busy. Thanks for the suggestion I will look into this more once I finish my hardwood flooring project.
                I have several of these and found them to be quite useful:
