I had myself about talked into a Conrad Johnson 17LS2 preamp when I noticed a comment that it output its signal in inverse polarity. Did some research and ended up not any more knowledgeable. Two channel reviewer just says reverse cables on speakers (which fails to account for HT bypass). Other discussion on the boards seems to fall into the "you cannot hear inverse polarity" camp or the "if you cannot hear it you are a moron" camp.
What has been your experience? Is this a big issue or much ado about nothing?
