I am trying to input two amplifiers (separate rooms) from the Sky plus optical output. Both work individually, so the signal's fine. I've tried a 'Y splitter', but guess I understood it's function the wrong way round as neither worked when I tried it.
As I understand it 'Optic Switches' direct the beam so that only one receiver can be fed at a time, not both simultaneously?
Is this correct, or is there a way so both can be utilised at the same time?
Any ideas or advice gratefully received.
