Does anyone make a small amp, 2-3 channel, like the Gizmo with IR (remote) volume control?
who makes a mini amp w/ remote
I've been looking for an option like this also.
My criteria are:
AFFORDABLE
Sub out
Built in crossover (variable would be nice)
Remote
Small-ish form factor (more compact than standard AVR)
This has been impossible to find so far.
If I forgo the remote requirement, that leaves me with Gizmo (which I have), or the Virtue One amp modded to have a set crossover.
April Music Aura Note
This may be out of the "affordable" criteria, but I was reminded of this CD/Amp:
(it does have a remote)
Link
There's also the Peachtree Decco, which is a nice integrated with a high quality DAC.
http://www.crutchfield.com/p_731DECB...ck.html?tp=180
At the lower end there are lots of small systems from Onkyo, Denon, NAD, Yamaha and others - that show up under the shelf system category on most retailer websites. I ended up getting a JVC EXD5 for my wife when I did a search for a small receiver with a remote and CD built in. We've been very happy with it, having gotten it on clearance for $199.
http://www.amazon.com/JVC-EXD5-Syste.../dp/B0007XH71U
If I were looking for myself, this NAD, would be something I'd be considering.
http://www.audioadvisor.com/prodinfo.asp?number=NAC715
Jim C
