If this is your first visit please review the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I've got a Duet hooked up using optical to my 5 year old Denon AVR. I'm wondering if I should use the internal Squeezebox DAC by connecting via the digital coax or the L/R RCA connections.
Any thoughts?
To use the DAC in the Squeezebox you'd have to use the L/R RCA connections, the Coax is just another flavor of digital just like the optical (for digital many believe coax to be superior to optical - in my system I can't hear a difference).
Depending on how your receiver works, it is worth hooking up both analog and digital - with my old Yamaha on some material it sounded good using the Receiver DAC's on others the DAC in the CD or Squeezebox sounded better.
At the least it gives you a good comparison of the qualities off different DACs and an idea of why people often end up going to outboard DACs.
