Blackgate N series replacement suggestions?
  • Blackgate N series replacement suggestions?
    I'm looking for a couple (each) 4.7uF and 10uF 50V N series Blackgates....
    but can't seem to find anyone with any on hand.
    Would anyone be so kind to have any I could buy 2 of each from?
    Otherwise, recommendations for replacements? Need something small and will be in the signal path (some mods to a SB3).
    Thanks!
    Dave
    Going to start hacking my squeezebox soon...
    Trying to simplify the setup a bit... and hoping the analog section once tweaked will be on par or better than my external dac...
    DAC chip has already been upgraded...
    Got some LM4562s, OP2107s and AD8066s op amps on the way...
    Decided to go with the Nichicon Muse ESs in the signal path (need something small... not much room in there), and some silver micas for the feedback filter circuit. Also picked up some new rca jacks... but may not put those in... will see.
    Should be a fun, simple, little project.
    Dave
      Simple... bah! dang it's tight in there. That or I have fat fingers.
      opamp was the easy thing to do - put in the LM4562.
      Swaped out the output caps and added the silver micas...
      It's playing away... but I got a little package from Oppo :woo: that needs to get set up. So no listening impressions for now.
      Dave
        B Ray? :idea:
          Maybe... :yes:
          Although still futzing with the audio...
          And haven't touched the video (out of the box it's pretty sweet!)
          Using 5.1 analog out and my sub doesn't seem to be getting any signal.
            Mods already :salute:
