Anyone using an Apple TV as a music server? Thoughts? Thanks
Apple TV
Originally posted by uw69Anyone using an Apple TV as a music server? Thoughts? Thanks
you can buy an airport express and have a music server for a lot less, just depends on how you want to do things....
Sean
I tried it out (model from last year), but in the end, I decided that it wasn't really worth it and got a PS3 instead. I bought Nullriver's Medialink ($20) and the PS3 ($320 in December) streams all my music, pictures, and videos, and has Blu-Ray.
It definitely works pretty seamlessly though if you use a Mac, and the interface is pretty much like front row. If simplicity in setup and use is what you want, then there you go =)
IMO, though, there are better options that are just as easy and more capable w/ more options like my PS3 setup (it also works with the Xbox 360 the same way).
Originally posted by intendedaccelI have a PS3, Apple TV and a Tivo HD. I like the Apple TV a lot for music playback, but I'm fully tied into the apple ecosystem. If you are ok with that, then it is great, otherwise I'd stick with something like a squeezebox for music only.
If you use the HDMI out on the Apple TV to a HDMI 1.3 AVR are you using the AVR's DAC? Thanks
Originally posted by uw69I'm "all in" using iTunes and the Apple TV seems to be the only way to play purchased music files from iTunes. Is the sound quality of the Apple TV good?
anyway, I have a co-worker with an Apple TV as well as a PS3 running Tversity. He likes both, but uses the apple TV for comtrolling his outdoor speakers since the Wifi iPhone can be used as a remote control.
My favorite thing is the HD movie/tv show purchases/rentals. Makes unbox on the tivo look stupid functionality wise, and has a great picture and sound.
