Wall mounting a 46" Plasma TV
  • Wall mounting a 46" Plasma TV
    I'm looking to wall mount my Plasma in order to fit Bigfoot Center Channel on the Stand that currently supports the TV. I need a mount that will allow me to move TV to the right of where the Mount will go up on the wall. I am looking at a Monoprice model that should do the trick
    http://www.monoprice.com/products/pr...seq=1&format=2
    Anybody out there want to throw in their 2 cents worth. I will add pictures to illustrate what I am going to be doing.
    This picture sucks. i will add better one later which shows wall behind TV where Mount needs to go
    That is a beefy mount. If the studs are where you need them to be it should work.
      Be sure the holes for the wires are large enough for your situation.
      PhenomeNhan Audio Video
      [email protected]
