We are doing a bid for a company building out a new restaurant here in Seattle and I'm in charge of the A/V estimate. I was looking up the speakers that were spec'd and came across this brand: Martin Audio. I'd never heard of them before so I go to their website and on the front page is this beast: http://www.martin-audio.com/products/asx.asp
Specs:
Yeah ... 152db peaks! That's louder than a jet engine at 30meters. 8.5 THOUSAND Watts! Now if it just went down to 10hz ... :biglaugh:
Specs:
FEATURES
* Ultra-efficient, with 152dB @ 1m half space maximum output
* Hybrid® large folded horn and ported design, -3dB @ 30Hz
* Single 21" (530mm)/6" (150mm) voice coil driver with 2.4" (60mm) peak-to-peak excursion
* Dedicated Class D amplifier with 8.5kW peak power
* Switched mode power supply with PFC (Power Factor Correction) and global mains voltage operation
* DSP on board providing delay, EQ and filtering as well as amplifier and driver excursion limiting
