For those of you that like to use a computer as your source (like me), ASUS has two audiophile cards in their lineup. The two channel card, the Xonar Essence STX, has already been released. The eight channel card, the Xonar Essence ST, has not yet been released. Both cards have the following features:
The Xonar Essence STX is a PCI-E card and the ST is a PCI card. The ST adds an expansion card for the addition 6 channels.
Here are some previews of each card:
ASUS Xonar Essence STX
- Burr Brown 1792A DAC chips with 124 dB SNR
- RCA output jacks
- Independent power sources for line and headphone outputs keeping the signal clean and clear and eliminating any interference between output sections.
- Swappable opamps (on all channels individually for the ST)
- EMI shielding - the sensitive analog electronics are sealed and protected from harmful EMI/RFI behind a carefully designed shield.
- New hyper grounding circuitry design allows sensitive analog paths to be isolated on the circuit board keeping them free from noise and interference.
- Nichicon “Fine Gold†Professional audio capacitors offer rich bass and crystal clear high frequencies.
- Built-in headphone amp - A high-quality TI TPA6120A2 headphone driver supports headphones up to 600ohms of impendence with lower than 0.001% distortion.
