Room / Speaker Analysis and Calibration / Correction
updated: 1-11-2011
* Under Construction !!! *
Audyssey
Audyssey Basic starter-links (from soundlvr @ AVS):
- Audyssey homepage
- types of Audyssey implementations in different receivers (and other electronics)
- Audyssey FAQ
- Audyssey setup guide (from giomania @ AVS)
- AVS - "Official" Audyssey thread
- Stereophile review
- "Audessey [sic] professional calibration worth every penny" thread (@ AVS - David Shapiro) - link
Dayton OmniMic Precision Measurement System
- CHT post (this thread) = Post #12
- AVS link
Room EQ Wizard (REW)
- REW
- REW V5 Beta feedback - HomeTheater Shack thread
XTZ
- XTZ Room Analyzer
- XTZ "Buy & Try" program
- XTZ Stereophile review by Kalman Rubinson
Two channel <$1K EQ devices to look at (listed by Kal Rubinson @ AVS):
JBL Pro
KRKSYS
SPL meters, sub calibration, etc." thread (@ Home Theater Spot - Mike_TX) - link
Sound Pressure Level (SPL) Meters
- Galaxy Audio Check Mate (CM) 130 - link [no line-out, so not for REW, TrueRTA, etc]
- Galaxy Audio CM140
---- link
---- S&V mini-review - link
- Galaxy Audio CM150 - link
- Galaxy Audio CM160 - link
- Galaxy Audio CM-C200 SPL meter calibrator - link
- Radioshack (RS) Analog model 33-4050 - link
- RS Digital model 33-2055 - link
Note (from HTShack):
"We recommend the Behringer ECM8000 microphone (with a proper preamp) or the Galaxy CM-140 SPL meter for full range measurements. Limit your measurements with the Radio Shack SPL meters to 3KHz." - link
Rives Audio test kit - link
$690 standard
$1000 professional
GA CM # / MSRP / Amazon / Selected Fx
130 / $75 / $60 / inexpensive
140 / $150 / $120 / *
150 / $340 / $250 / * + graph, RS232 interface, Auto Ranging (30 ~ 130dB), auto power off
160 / $525 / $350 / * + (above) + internal memory
CM-C200 / $340 / $250
* -140, -150, and CM-160 meet the same IEC 651 Type 2 standards for SPL meters
GA CM # / Accuracy
130 / +/- 2 dB
140 / +/- 1.5 dB
150 / +/- 1.5 dB
160 / +/- 1.5 dB
SPL Meter - Other and Test Tones
- General SPL info - S&V Review 8/2008
- correction charts
---- Excel Workbook files (HTShack) - link
---- JPG of correction chart (from ElTwo) - link
---- SVS site comments - link
- CD corrected tones for RS meter
---- Rives Audio Test CD 2 - link
---- NOTE: Rives Audio CD does not correct for the Radio Shack digital SPL meter - ref
---- Rives Audio Test CD 2 Instructions - link
---- Rives Audio Test CD 2 CHART (color) - link
---- Rives Audio Test CD 2 CHART (B&W) - link
- CD UN(?)-corrected test tones
---- av123 Subwoofer Test Tone CD - link
---- Real Traps Test Tone CD - link
- Circuit modifications - RS model 33-2050 - link
Subwoofer Calibration/Optimization Links
- A-holics (8/2008) An Easy Solution To Subwoofer Calibration - link
- A-holics (8/2004) Subwoofer Calibration Using Rives Audio Test CD 2 - link
- Avia Subwoofer Calibration tips - link
- Bossobass - Subwoofer Setup Guide by Bossobass - link old (see PDF enclosed)
- Robroy Common Subwoofer Setup Errors - link
(for some broken links from A-holics you might have to look at the link and Google search or re-type in manually the link)
Other Subwoofer Links
- Myths about Subwoofers (Audiopulse) - link
Subwoofer Equipment for Calibration/Optimzation (not SPL meters)
- AV123 R-DES (no longer made)
---- Review - Secrets of Home Theater & High Fidelity 9/2006
- Behringer Feedback Destroyer (BFD) Pro DSP1124P - link
- Behringer Ultradrive Pro DCX2496 - link
- DSPeaker Anti-mode 8033 - link
- Rives Audio PARC (Parametric Adaptive Room Compensation) - link
- QSC DSP-30 - link
- SVS AS-EQ1 Subwoofer EQ - link
- Velodyne SMS-1 - link
*add or organize* - with Audyssey, XTZ, Emo-Q (???), MACC, REQ
Trinnov, RoomPerfect, MRC
Home Theater Spot -- Room Acoustics Discussion Forum
Thread link
HT Acoustics FAQ link
Education
GIK Acoustics (Education) - http://www.gikacoustics.com/education.html
Sound Isolation (Green Glue) - http://www.greengluecompany.com/technicallibrary.p...
Useful Links
Acoustical Treatments that Don't Work (HTS) - http://www.hometheaterspot.com/showtopic.php?tid/1...
Acoustical Forum (Rives) - http://www.audioasylum.com/forums/rives/bbs.html
AVS Forum
Services
Erskine-Group Architectural Acoustics- http://www.erskine-group.com/
Rives Audio - http://www.rivesaudio.com/
Seaton (Mark)
Companies / Products
Fiberglass (703) - ...
Fiberglass (705)
GIK Acoustics - http://www.gikacoustics.com/
Guilford OF MAINE (GOM) fabric - acoustically transparent
--- GIK - http://www.gikacoustics.com/gom_fabrics.html#build
Green glue - http://www.greengluecompany.com/
RPG Diffusor Systems - http://www.rpginc.com/
QuietRock drywall - http://www.quietrock.com/quietrock-drywall.html?_k...
Calibration CD / Software
See also:
- "SPL meters, Sub calibration, etc" thread - http://www.hometheaterspot.com/showtopic.php?tid/1...
I thought it would be useful to have a summary of room and speakers analysis programs and equipment for people to refer to.
I am no means an expert on this and have only used Audyssey and Audyssey Pro, but I think as the subs role out from TCA that the ability to measure and share data will be helpful.
Please let me know what to add...
updated: 1-11-2011
Audyssey
- Audyssey homepage
- Audyssey FAQ
- AVS link
- REW
XTZ
- XTZ Room Analyzer
JBL Pro
KRKSYS
---- link
$690 standard
$1000 professional
GA CM # / Accuracy
130 / +/- 2 dB
140 / +/- 1.5 dB
150 / +/- 1.5 dB
160 / +/- 1.5 dB
- correction charts
- QSC DSP-30 - link
Thread link
Education
Useful Links
AVS Forum
Services
Seaton (Mark)
Fiberglass (705)
See also:
