Let me start out by stating that my post is PURLEY SUBJECTIVE.
I realize that other persons hearing, preferences, and opinions may be very different.
I’m quite OK with that, and that’s one reason we have such a variety of recordings and sound reproduction equipment out there.
Having been exposed to live music performances for several decades, I will describe my personal preferences first.
Music Types -- Old style rock, blues, a little country, and a little jazz.
Venue Size -- Small to medium (no dimension over 50 feet or so)
Listening Position -- About 15 feet front center of stage
Drum Kit --Not amplified
Horns -- Not amplified
Bass Guitar -- Big standup multiple driver amplifier.
Other Guitars -- Individual on stage amplifiers
Keyboards --Through some good stage subs, if really low notes are used.
Vocals & Everything Else -- Through a good smooth sounding PA
Even though some of the performances were lacking compared to commercial recordings, the sound was superior to my own home stereo, and stuff at high end audio stores as well (Assuming the sound was even half decent at the venue).
Now I’ll get to the differences I usually heard.
I would often sit with eyes closed and really concentrate on exactly what I was really hearing.
Ambience …Gobs more around about 60-200Hz
Drum hits bounce around everywhere.
Much more sense of space, and envelopment.
Overall Volume -- Usually higher.
Dynamic Peaks -- Higher on hard drum hits in particular.
Imaging -- Surprisingly “not as precise†as most recordings, unless you stood right up front at stage edge.
Bass Drum -- Lots of smack & concussion, but much less thump or boom tone.
Other Drums -- Louder than in most recordings with much more sound of the shells.
Cymbals -- More ring, clank, and shimmer
Saxophone -- More growl, and bite
Trumpets -- Sharper and more metallic with a bit of buzzy distortion (even unamplified).
Bass -- Usually fuller, louder, and warmer, with better definition of individual string and low pedal note vibrations.
Vocals -- Similar, but not as prominent compared to most recordings.
This got me & an audio enthusiast friend to wondering .
How much of the difference is our playback hardware, and how much is due to the way our recordings were made.
So, we decided to roll a few live recordings of our own to help us figure out where the differences were.
We went armed with only a very minimal recording setup.
Tape Deck
Pair of mikes
Monitoring headphones
DBX compressor limiter set only to take a catch a few over the top snare hits that were saturating the tape.
Recording position was optimized by adjusting the height & vertical angle of the mikes while monitoring through headphones, until the sound seemed focused right.
We then mover in closer to the stage by ½ the distance to compensate the playback having only ½ the reverberant field from two front speakers.
Playback was done through my big ole set of Acoustic Research AR-9 floor standers fed with 300wpc (little over 400wpc peak headroom).
EQ was tweaked by ear with my 1/3 octave Equalizer to compensate small inaccuracies in the recording/playback chain until it sounded as much like the performance the night before.
Cranked up the volume to a live level and OHHHH MYYYYY GOD. :whew:
I had never heard anything so live sounding before.
Even my so called audiophile discs seemed somewhat lifeless in comparison.
The only differences between live and recorded were a very slight loss of clarity, and bass drum impact.
Also, a drier kind of back to the wall type reverberant field with a less energized air sensation.
SUMMARY
The difference between live and recorded is roughly about 90% in the recording process and 10% in the playback equipment. Boy am I going to ruffle some feathers with that opinion !! :stirthepot:
Of course, this assumes the playback system is pretty accurate, SPL capable, and properly adjusted.
The vast majority of recordings are heavily processed in many ways to please the target audience, and maybe sound “livelyâ€, but not live.
Tape Deck
Pair of mikes
SUMMARY
