help in selecting wires
  • help in selecting wires
    Hello. Just bought A5RX. What brand of wires to buy and where? Thanks
    How much speaker wire are we talking about? I just bought a 250 ft roll of 16/4 CL4 (in wall rating) for $35 to wire for my Atmos speakers. If you are running "out-of-wall," you can cover such wire with a nice jacket & heat shrink tubing at the banana plugs.
      https://www.bluejeanscable.com/store/speaker/
      https://www.amazon.com/gp/search/ref...nid=3605284011
      a starting point. I just use a 12 ga monoprice. Any of the good quality companies would be fine. Some swear they hear the difference using ultra expensive cables. My ears cannot tell.
        Just using about 20' direct to speakers from amp.
          Thank you for the links and advice.
