If this is your first visit please review the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Probably the best way to understand what an HDR image is this. Each shot (5 different shots) was taken with different settings, then the best is taken from each of those shots and merged into 1 image. Then that image is "tone mapped" (in this case, I used Details Enhancer in Photomatrix). And further processed in CS4.
BTW, you give all of us complex by posting these beautiful shots. :)
BP, good to see you over here. Thanks for the kind words. I am really excited about shooting HDR's. BTW, I found a good video on how to set this up on a D300. Let me know if you would like a link to it.
I have had several folks wanting to buy a print of this. I may do a limited run and let my youngest daughter sell them (and she can keep the money). Don't know yet.
I am planning several other opportunities for HDR shots in the spring, when the flowers are in full bloom. I may *need* to get a 70-200 VR lens with a 1.4 or 1.7 TC to do the shots I want.
Can you save me the Googling and give a 30,000 foot view on what exactly a "5 shot HDR" is? Thanks.
One way to look at HDR is ...
HDR or High Dynamic Range Imaging is a technique where you combine multiple pictures taken to overcome the high dynamic range of
a scene, which otherwise is not possible to capture due to limitations of digital sensors. For example, if you are trying to shoot something
which has lot of details in shadow areas as well as some very bright parts too (something which may have bright sunshine and a lot of shaded
areas in the same scene), typically it is not possible to capture it accurately on single frame, as you will most likely end up either under exposing
shadow areas (and get lot of noise in the picture) or end up overexposing brighter parts of the scene (and loose details in blown
highlights). This is specially a limitation of all current day digital sensors irrespective of make/model. To overcome this issue, what
you do is that you take multiple pictures with exposure bracketing, for example take 5 pictures with 1 picture at correct exposure
setting and and 2 each on over and under exposure side. They will be something like exposure setting at -2EV, -1EV, 0EV (correct
exposure per camera's exposure metering or you own manual metering using light meter), +1EV, +2EV. After these you get these on
computer and merge them using a software like what Mike used Photomatrix or Photoshop etc and results are beautiful like the one Mike has posted.
Simple. Isn't it? :)
