I have a Onkyo with audyssey mutli Eq. I tried different placements for my sub and decided between the front mains to be the best. I ran all six points of audyssey. At low volumes is sounds good, but at louder volumes the bass sounds sloppy or muddy. I tried running with audyssey off made a little difference. I keep messing around in the settings and noticed you can manual Eq each speaker. I messed around with the adjustments for the sub to try and tighten up the bass. Here's the bandwidths I can adjust.
25Hz
40Hz
63Hz
100Hz
160Hz
Each on of these can be adj for -6 to +6 all were set at zero. Any help on which settings I should mess with?
By the way I'm using a MFW. :peeping:
Thanks
25Hz
40Hz
63Hz
100Hz
160Hz
Thanks
