I just bought a new Onkyo receiver. After reading the manual it states the OSD can only be displayed using Hdmi. Problem for me since the TV I use is old and used just for OSD with no Hdmi's, it only has RCA connections. Is there some sort of switch I can use to convert Hdmi to composite?
No Hdmi for OSD
Composite video is formatted differently from component and HDMI (YUV vs YPbPr). I don't really understand what all that means, but I think the bottom line is that a powered smart device (some kind of converter) would be required. I think Amazon can help you find something for about $50, but I say it's time to upgrade! Of course, inconvenient as it is, the OSD is likely not required for any of the functions.
Originally posted by HopefulFredComposite video is formatted differently from component and HDMI (YUV vs YPbPr). I don't really understand what all that means, but I think the bottom line is that a powered smart device (some kind of converter) would be required. I think Amazon can help you find something for about $50, but I say it's time to upgrade! Of course, inconvenient as it is, the OSD is likely not required for any of the functions.
