What format do I need? I want to get on burning the scubasteve demo. I have a step by step already downloaded so I don't screw it up, just need the 'write' media. :doh! 1:
Burning a BluRay
Burning a BluRay
HO's Basement Take 2Tags: None
BD-Rs, 25GB if it will fit on there. I'm not sure what the scubasteve demo is. You might just want to get some BD-REs so you don't have to worry about pricey coasters.
Most posts made under this account probably influenced by "kool-aid". Done drinking what Chase is offering, and my current views have significantly changed.
Gator-
I 'think' the demo is around 45-50 GB.
Does that get compressed or anything when I burn it?
I know he burns it to one BD when he sends it out...
Guess I should just buy a pack of REs and figure it out....:eek:
EDIT: Holy @#[email protected], $85 for 6 of the 50 GB discs? WOW-Greg
A BD-RE 50GB is between $40-50. What have I gotten myself into.
So, is it get 1 RE to make sure my method is right, and then a 6 pack of BD-Rs to do some others...hmmm-Greg
Oh, heck yeah, I know what you're talking about now!
Awesome demo disc.
I just used my HTPC and mounted the iso. :(
I don't know if a $13 potential coaster or a $40 RE is the better way to go. Those things ain't cheap!Most posts made under this account probably influenced by "kool-aid". Done drinking what Chase is offering, and my current views have significantly changed.
Originally posted by LilGatorOh, heck yeah, I know what you're talking about now!
Awesome demo disc.
But I'm working out a deal with a buddy to swap the scubasteve BD for the old demo discs. :D-Greg
Originally posted by HuskerOmahaA BD-RE 50GB is between $40-50. What have I gotten myself into.
Sony BD-RE 50GB Blu-ray Re-writable Disc for $22.95 each.
I downloaded and burned the scuba disc and it is pretty good. On the thread they had going, I saw several folks suggest buying a pack of 3 Sony BD-RE DL 50GB discs on ebay from a seller named j-stop, which I did.
Worked very well and I am pleased with the end result.
Just checked and he has a "Buy It Now" deal for $37 (free shipping). Add $3.99 for insurance.Ray
