Wine openers?
  • Wine openers?
    What are your favorite wine openers?
    I just buy screw top or box wine. :)
      There is some insight in that.
      And utility.
      No box wine here...
      :snaggletooth:
        Definitely the "Screwpull Rabbit" is my favorite, although I also have a nice "Screwpull Standard" that sees much action! A nice foil cutter is key, as well. It is surprising what a difference it makes to twist the foil cutter and have a perfect cut just before you use your lever action corkscrew to smoothly pull the cork (without excess force or wine bruising pop).
        Cheers!
        Tweak City Audio WAF-1, Paradigm PS1000, Jolida FX-10 tube amp, Samsung Blu-ray, Beresford TC-7520 DAC, Apple Airport Express (living room)
        Other stuff: Usher S-520, JohnBlue JB-3, MiniWatt, Glow Amp One, Nuforce Icon Mobile, Sennheiser HD595
          Thanks.
          I've used both of these.
          My "rabbit" version just broke - cheap plastic.
          I was hoping there would be a metal version.
          Anyone use this:
          Metrokane Vertical Rabbit Lever Style Corkscrew with Foil Cutter, Candy Apple Red
            That mono Rabbit looks really nice!
              Here is what I use and I have had it about 18 months I would guess and it has opened many bottles and does a fantastic job for the price.
              http://www.amazon.com/Oster-4207-Ele.../dp/B000COC5MK
                Electric opener
                I have been somewhat wary of the electric or forced gas openers.
                Why do you like it?
                  I use that and my friend uses I think its a waring, but very similar. I would give it my full endorsement. These new electric types are really smooth. Yeah, they are large but talk about hassle free, and cool. The new Rabbit electrics look awesome, but get pretty poor reviews.
                    I've had this for over 2 years and it works well. the only thing
                    it doesn't open are the bottles that have a wider or flared top to them.
                    Remove the foil (comes with a cutter) and place on top of the bottle
                    while holding the bottle in your other hand. Push the "down" button
                    and hold the bottle while it screws into the cork and reverses and pulls it
                    out. When done, you push the "up" button and it unscrews from the cork
                    and plops it into your hand. Maybe 10 seconds from start to finish.
                    I think it works great!
                    -M
                      Okay.
                      Cool.
                      I ordered the Oster Electric Wine-Bottle Opener (Merlot).
                      I have a wine cooler in the kitchen as well as a bar, so if I don't like it as a main opener I can relegate it to the basement bar.
                      I think I'll still get another "manual" opener, so keep the comments coming.
                      Thanks.
                        I have several different types, but I like the simple waiter's corkscrew.
                        LG 60PS60/BD390/Integra DTR-6.9/RS850/RS450/200/RS300/MFWx2
                        LG 42LH30/BD590/Peachtree Nova/Parasound HCA-1200/PB Minis
                          I worked as a waiter for a year after high school and have to admit the waiter's corkscrew is my favorite. Reliable and cheap. :rock:
                            I waited tables and tended bar for years. Have had several wine serving classes and have hired and trained other waiters and bartenders.
                            I find that a simple sommelier knife is very dependable. Mine even doubles as a beer bottle opener, which tends to get more usage than the corkscrew around here nowadays.
                              My favorite
                              Even though I am late to this discussion - since you ordered one already.
                              The one I like is the Screwpull pocket version.
                              http://www.amazon.com/Screwpull-Creu...2594169&sr=1-2
                              When I went for a private wine tasting at Robert Mondavi Winery, they gave each guest one. Since then (~ 20 years), I have gifted over a dozen to friends and relatives and they all love them. I still use the original Mondavi one and have them in my suitcase, computer bag, and car....you just never know when you find a great bottle of wine to try.
                              Happy tasting,
                              Lou
