looking to have some audio in the backyard.........what kind of speakers, cables, electronics.......any recommendations.........any websites ??
outdoor speakers
Originally posted by soundofrocketslooking to have some audio in the backyard.........what kind of speakers, cables, electronics.......any recommendations.........any websites ??
HTS thread
I'll dig up more (eg my AVS HT build thread...)
MikeHT Gear (AVS Link)
Outdoor speakers
Originally posted by soundofrocketsthanks for the link..........which ones did you end up buying and what has been your experience with them..........since then has there been any significant advances ??
I have scattered links and info on Outdoor speakers.
An outdoor speaker FAQ for HTS is on my "To Do" list.
You can also check out this post in my AVS HT build thread:
Link
That has a lot of links including to other AVS threads.
However, even at AVS the number of threads is small and professional reviews are rare.
Another thread:
Seaton Forum "Seaton Outdoor Speakers"
Other links:
"6 Awesome Outdoor A/V Products"
6 Awesome Outdoor A/V Products By Robert Archer Outdoor entertainment is a lot more attainable today than people think. Here are six of the best outdoor A/V products. There's nothing like sitting on a deck or patio during a warm sunny day with some friends enjoying good music. Outdoor...
CHT/TCA - "Outdoor Subwoofer" - link
I started up this FAQ at HTS where I will try to assemble a lot of disparate links...
HTS FAQ thread
It will take me a little while to clean it up and then add to it...
Mike has been more then helpful in the outdoor speaker department. Not that I have anything to compare them to, but I purchased 2 pairs of the Def Tech AW6500 and they fill my pool, deck and back yard nicely. They sound good and have surprising bass response, considering the 15 year old kenwood receiver I am running them with. In addition, they are very easy to install. I would recommend them to anyone, I have them sitting under the soffit below my gutter's to keep the majoraty of the weather off of them. If you want PM me and I will give you the contact info of the Def Tech Authorized Etailer I bought them from.
thanks for all the links Mike.......and those def tech speakers look nice but expensive......and looks like they need to be protected from the elements......maybe a good choice for covered patios etc......what about the backyard or uncovered patios.......and what type of electronics......same as for HT purposes or are there special ones for outdoor use........
Amps / 70v
Originally posted by soundofrocketsthanks for all the links Mike.......and those def tech speakers look nice but expensive......and looks like they need to be protected from the elements......maybe a good choice for covered patios etc......what about the backyard or uncovered patios.......and what type of electronics......same as for HT purposes or are there special ones for outdoor use........
You can use multi-channel amps (eg Russound, Niles, etc) purposed for the task or extra channels on AVRs or separate amps or AVRs.
Some setups have 70v amps for the task.
Check out here as one source of info...
The 70V ceiling speakers from Outdoor Speaker Depot are very popular for commercial applications and have a built-in transformer for multiple applications.
Originally posted by soundofrocketswhat about the processor ?? i will use my older oppo player as source.......i wil need something to process and something to amplify....hence the idea of using ht based avs something like refurb onkyo or something similar......
