Does cable quality make a difference for power cords? I am considering buying 2k worth of power cords for only a few hundred bucks at a liquidation. What do you guys think? Worth it?
it all depends on the quality of power coming out of the outlet.
i would say spend the money on getting a balanced power conditioning unit like an equitech, versus spending 2k on cords. or put that money into buying acoustic treatments and sound isolation products.
you will get a bigger difference in performance doing either of those then a power cable.
just be warned this is beyond a hot topic. speaker cable debates are one thing but this is far more dangerous territory.
*time to duck and cover* :hide:
MattStill think Craig is in the "Chase" for that sense of humour. :neener 1:
Matt, read the original post.
You are assuming that the OP doesn't already have treatments and conditioning. :neener:
Reminds me of a couple years ago when suddenly my Comcrap internet started intermittently dropping. This was likely due to the capsule in the front yard being 50% destroyed and water getting into it every shower....which is when the problems happened. They had to send out a tech though and I had to be there. First thing this guy does is want to check the signal at my router then proceeds to recap my connectors on the exterior. While doing so he comments that my house is wired with old crappy RG-59 and that I should pull new RG-6.
We then proceed to the partially intact capsule at the street. When he pulls of what little remain cover is there I say "well lookie there", and when he asks what I say "Comcrap is using ****ty old RG-59 for the feeder cable to my house". He didn't have much else to say other than the problem was on their side.
I know this is debated over and over again but I just don't believe you can better the quality by improving the last couple feet of wire.:stirthepot:
Originally posted by tesseractMatt, read the original post.
Like Art said, if he doesn't like 'em, he can easily sell them and recoup the cost.
my point still being, that it's only worth any real value if the stuff coming out of the outlet is good clean power..
and my opinion still stands that its better to spend money on high quality power conditioning and treatments... there are lots of things that DO increase audio quality that can be added to a system, power cables are about the last thing that really need to be considered. unless it is just a style thing and all that is wanted is a particular look. Which is why i am building my own power cables, i just like the look of those big techflex cables. thats it. I don't see anything in eletrical engineering literature that would lead me to think that spending money on esoteric power cables is going to lift some sort of esoteric veil from the esoteric music that I listen to through my esoteric speaker cables and esoteric interconnects and even more esoteric tweaks like little near microscopic bronze bowls placed randomly around the room..............................
:idea: maybe read my post again....
A few hundred dollars is not inexpensive when it comes to cables. That money is likely better spent at other places in your system, though I can't say for certain as I don't recall what you have. Don't spend money on stupid stuff IMHO, spend it on great speakers, well designed inexpensive amplification, room treatments, and music.
The 'buss being sold through GR Research will filter power and make a noticeable difference for a few hundred dollars. I'd recommend that route for most people vs. just buying power cords."Sometimes I think the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us."
-Bill Watterson
Originally posted by je5u5_faced_assassinDoes cable quality make a difference for power cords? I am considering buying 2k worth of power cords for only a few hundred bucks at a liquidation. What do you guys think? Worth it?
I made a custom power cable, got a slight improvement in sound.
Got far more benefit by replacing the 0.59 cent outlet it plugged into with a $10 hospital grade outlet.There's a fine line between gardening and Madness.
Originally posted by Steve_vai_rulesi did read the original post............... my opinion still stands that its better to spend money on high quality power conditioning and treatments...
:idea: maybe read my post again.... Matt
Originally posted by tesseractThis is a given, but the OP asked if power cables were worth a try. At that price, I say get them, try them, sell them if you don't like them.
Microscopic bronze bowls? You have been spending too much time on AVS. :neener: Those guys go a little too far with the objectivity view.
"near microscopic" not microscopic.
Originally posted by Steve_vai_ruleslittle near microscopic bronze bowls
Matt
Originally posted by Steve_vai_rules"near microscopic" not microscopic.
Matt
