Is this a good deal
  • Is this a good deal
    I just found this and not sure if it's a deal or not.
    http://www.ecost.com/detail.aspx?edp...t.l.google.com
    Any input is appreciated.
    Hugh
    MELODY US Distributor
    www.angelcityaudio.com
    A man is only as good as his words.
    Yes if you truly want/need a 'netbook'.
    Frankly, I'm not sold on the usefullness of them.
      Agreed.
      I used to lug around a 17" laptop when I travelled and it's just killing my shoulder being an old skinny guy. :)
      Hugh
        It'll be really slow. It doesn't even have an Atom processor.
        With a shovel...
          Of course, it has more than twice the original spec for XP, so if you are just using it for internet/email it may be just fine.
            Keep in mind that the hard drive is solid state and comes with only 16 GB. You'll run out of memory really quickly. Consider getting one with at least 160 GB.
            PhenomeNhan Audio Video
            [email protected]
              My netbook w/ an Atom drives me nuts! It's such a dog. It might be more than the original spec for XP, but it still sucks. :p
              I can't wait to sell it.
              With a shovel...
                Here's something from BestBuy's outlet (not sure if it is a refurb unit or not) for $280. I'm sure the tech guys can chime in and dissect the specs for you :)
                http://www.bestbuy.com/site/olspage....=1218095770701
                [email protected]
                  I'd probably spend the extra $80, although I'm not sure that's the best deal around at a mere $20 off. If you go atom, make sure it's the dual core model. A SSD will restrict storage greatly, but will also extend battery life and be quite a bit more responsive than a 5400rpm drive. That's gonna mostly depend on what the purpose is. If you want to stick 80GB of lossless music on it to listen to on the road, the SSD won't work. If you just want to surf the net, check email, type notes, listen to pandora, etc. then the SSD might be a nice boost in speed.
                    There are no dual core Atom netbooks.
                    With a shovel...
                      I stand corrected. I've not really shopped for netbooks, but I've looked at Atom based systems for a variety for reasons and the dual core ones obliterate the single core ones. I don't really know what an Atom netbook's real world performance is like.
                      I bought a standard laptop, but with a 14" screen for portability rather than the more typical 15". It cost more than something uber-portable, but I wanted to do multitrack recording on-location with mine so I needed a bit more juice. It's a Lenovo T400, and I've been pretty happy with it FWIW.
                        Anyone try one of the netbooks with linux loaded on it instead of windows? As I recall the linux version was supposed to be pretty usable.
                          I picked up this one http://eeepc.asus.com/global/product900hd-spec.html for my wife For $169 and she loves it. Unfortunately I haven't seen it advertised since.
                          Apparently you just got hypothetically banned by the unnamed new mods for the AV123.com forum that are working to clean the forums up on a forum that is currently closed. Sucks to be you :bite me:
                            The 8' display and keyboard is very small I would suggest the 10" models.
                              Hugh,
                              I have the ASUS EEEPC with the Atom processor, 1GByte of memory and 160GBtye drive. This one has the 10.1' display. Was $299 at Best Buy.
                              Using it for email, music server and development system.
                              The 802.11(n) WiFi works well with my D-Link N system at home.
                              As long as I use it with AC power for the music server it is fine. Battery power gives audio replay glitches. The Stello U2 USB to S/PDIF converter is working well with external DAC's.
