I ran this using the mic that came with my 247. After it was done I checked some of the settings. It had my fronts to large (which I changed to small) but it also had all my speakers set to different crossover points. I always read most people set them to 80hz so the sub does most of the work. I have a MFW for sub and when I calibrated with a spl meter I set it in the negative. After running Ezset it set it a 0 but the bass seems to be lacking. I'm know H/K is not as good as the Denon for auto calibrating, so would I be better off just starting over and calibrating manually.
H/K Ezset
Originally posted by dvenardosUsually the non-roomeq is good for given you a starting point if you don't know where to start or don't have an spl meter. Your ears and spl meter is the best judge.
I did the HK EZset on my AVR-247 yesterday, but stopped halfway through. Was it a "scary" event for you as well? I live in an apartment near school, and was absolutely shocked by how loud it had to be. I waited about 7 minutes, and seeing no end to the noise, cancelled it.
In contrast, the Audessey calibration on my Onkyo TX-SR876 was much quieter. Unfortunately, that one is back in a house where neighbors aren't going to be bothered.
So...question....how long does it take to run the full HK calibration?
Originally posted by blackzargI did the HK EZset on my AVR-247 yesterday, but stopped halfway through. Was it a "scary" event for you as well? I live in an apartment near school, and was absolutely shocked by how loud it had to be. I waited about 7 minutes, and seeing no end to the noise, cancelled it.
Keep in mind that EzSet has 2 components to it. It does both EQ and speaker leveling. I find that the leveling on my H/K AVR-254 is pretty much dead on. However, I don't like the EQ that it applies so I turn the EQ off. EzSet calibrates my sub too low as well.
As you've discovered if you can do a manual calibration you are definitely better off doing that instead of using EzSet.
-- jaydillyo
Originally posted by jaydillyoKeep in mind that EzSet has 2 components to it. It does both EQ and speaker leveling. I find that the leveling on my H/K AVR-254 is pretty much dead on. However, I don't like the EQ that it applies so I turn the EQ off. EzSet calibrates my sub too low as well.
-- jaydillyo
