Just picked up a used '08 car today (8k miles) from a dealer of the same manufacturer. And, in fact, it was a former corporate fleet vehicle belonging to the manufacturer as well.
So, I get it home.. and under the fluorescent lights in the garage I can see several flaws in the clear coat on the right side of the hood. They look sort of like big water spots, but definitely are not.
They didn't show themselves at all in bright sunshine in the dealer lot (I looked over the car very carefully), but it's aparent they're pretty visible under some other lighting conditions (maybe even overcast days? Not sure yet..) And, they're pretty numerous. (half-dozen or so, ranging from the size of a nickel to a quarter)
I'm going to ask the dealership in the next day or two if they can do something, but I'm not sure what. And, since they seem to be a flaw from the factory, can I even hold the dealer responsible (used car and all) to fix it?
I guess if the dealership can't/won't do anything, I'll drive by a body & paint shop and see what they say. But I thought I'd run it by you folks as well.
I'm trying to avoid any major fixe$ like wet sanding and re-spraying a new layer of clear.. though, maybe that's the only option.
I'd take a pic, but I'm not sure if I could get them to show up. The blems aren't very deep, but can be felt slightly by running a finger over the top of them. I'll see if I can get any of them captured in an image tomorrow, but I doubt it.
Thanks in advance.. :crying:
