If this is your first visit please review the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
I want to expand the runtime on my bicycle light. It is designed for 5 alkaline D cells, so 7.5 volts and I run 5 2200mAh Nimh batteries (6 volts). I was going to build a new battery pack with 6 rechargeable batteries to bump it back up to 7.2 volts and add a little bit of extra capacity. I am way to cheap to spend $60 on batteries. The ideal solution would be to load up on inexpensive AA Nimh and add a voltage regulator, but probably easier to just build two battery packs and switch them when the first one runs down.
I'd get a 2AA LED flashlight like this or this and a handlebar mount before I put any money into what you've got. It's probably brighter with comparable run time and it weighs a whole lot less.
Besides, added an extra cell isn't going add any extra capacity. Instead you will probably shorten your battery life, but you will get some extra light.
I will try to find it, but I do remember an article where someone took apart an energizer rechargable D cell and found out it's actually an AA with a plastic casing... shaddy stuff...
Somebody is a flashoholic. Those Quark lights look really nice.
Having gone through tons of bikelights and batteries (Halogen, LED, HID - SLA, NiCad, Nimh, Li-ion), I finally ended up with a dynamo hub.
Although initially a lot more pricey, a dynamo hub/light system gives you total convenience and decent lighting, while freeing you from having to think about batteries and charging. If you ride a lot, like winter commuting, or events like randoneuring where you need long run times riding overnight, ride in cold weather and frequently recharge - the dynamo system will end up saving you money over time.
Hey thanks guys.
You have to spend quite a bit of money to get an LED that is bright enough for going 20 mph in the dark. :yes:
Mainly I was just *****ing about the high cost of high capacity D cells, my simplest solution. :crazy:
